[ICEM] hybrid mesh unexpected growth in tetras
Old   September 16, 2022, 07:27
Default hybrid mesh unexpected growth in tetras
Dav[ID] is on a distinguished road
Hi all,
is still me, with the same mesh also, asking for your help.
I'm trying to produce an hybrid mesh for external aerodynamics computations on an ogive-cylinder body. The procedure I followed is detailed in this post:
hybrid mesh: update pre-mesh sizing of free surfaces only
The problem I'm facing is an inconsistent behavior in the size of the tetras in the volume of the free part of the mesh. The domain is a typical C-shaped domain, with a symmetry plane. On the symmetry surface the tri elements grow in the expected way and the mesh looks nice. Moving further from the symmetry plane (I would say in an azimuthal sense) things go worse and in the midplane (azimuth 90deg) I have the situation depicted in the pictures (the midplane is not an actual surface in the model).
I am quite inexperienced with non-hex meshes and I am wondering what could be the reason for this behavior.
Dav[ID] is offline   Reply With Quote
Old   September 16, 2022, 07:31
This are pictures of the exterior boundary of the hex region.
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 14:41
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
FLUENT - ICEM / Segmentation Violation Error (Hybrid Mesh) Joachim ANSYS 3 April 24, 2016 16:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[ICEM] hybrid mesh vmlxb6 ANSYS Meshing & Geometry 5 March 9, 2011 13:44
