[DesignModeler] Designmodeler missing external geometry after project archiving |
January 21, 2023, 22:11 |
Rep Power: 4 |
So I have a solidworks part that I imported into designmodeler for a cfd wing simulation, and I archived the workbench project to sent to another computer that can run the sims much quicker than my pc. I checked the 'archive external files' or whatever and the .sldprt was contained in the .wbpz file, but for some reason when I try to generate the geometry and mesh, it says the attach failed, could not find the part. I have the plugin installed correctly so I don't know why this would happen. Even in the attach feature, the part path is correct, and it opens the part in solidworks but doesn't change any parameters, just tells me the part couldn't be found (which it could, because workbench literally opened it in solidworks 2 seconds earlier...)
How can I fix this? |
Physical size of geometry in DesignModeler | Michael Rasmussen | CFX | 9 | June 16, 2017 03:27 |
How can make a 2D geometry DesignModeler? | Maldoror | ANSYS Meshing & Geometry | 1 | September 17, 2009 14:32 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
Virtual/Real geometry. | Jack Keays | FLUENT | 9 | June 15, 2000 23:39 |
