[GAMBIT] drawing absorber in Gambit
Old   November 3, 2009, 22:15
Default drawing absorber in Gambit
Lina
naftalena is on a distinguished road
im a beginner in CFD. i need help pls~ im working on absorber and need to draw absorber column using gambit..
for my case, the absorber is considered a cylinder with packing inside..i dont know how to draw the packing inside the absorber =(
anyone hv any suggestion on it?
naftalena is offline   Reply With Quote
Old   November 4, 2009, 01:33
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
draw the packing, and then substract it from the cylinder
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 4, 2009, 01:45
Lina
thanks max..
if i want to draw 2 inlet and 2 outlet, which gas inlet at the bottom, outlet at the top.. and liquid inlet at the top,outlet at the bottom. how to make sure they follow the correct path? because it seems that the gas exit at the liquid outlet..
lena
Old   November 4, 2009, 02:58
-mAx-'s Avatar
Maxime Perelli
In fluent for multiphase, I think you can enforce the vof value at the outlet.
But I am not sure
sofc geometry drawing with gambit. shunjie FLUENT 1 January 28, 2018 13:32
What a Strange Drawing in GAMBIT... teguhtf ANSYS Meshing & Geometry 3 October 5, 2009 11:17
how drawing using gambit zidane FLUENT 0 March 8, 2009 05:31
Problem of import solidwork drawing into gambit V.L. Koh FLUENT 4 February 27, 2009 09:01
Gambit drawing Peggy FLUENT 3 March 29, 2007 08:41
