Meshing 3D AHU room
Old   November 1, 2009, 02:01
Default Meshing 3D AHU room
Ch'ng Huey Khim
khimkhim is on a distinguished road
Hi all,
I have an AHU room model to mesh. I'm constructing my model in unit meter. I'm currently using Gambit 2.3.16...
I've meshed all faces before i go to mesh volume as my senior advised me to mesh the faces first if there is memory problem.
I then use Tet/Hybrid element, type TGrid, interval size 0.1 to mesh the volume, but it said "ERROR: Unable to allocate 14425056 bytes of dynamics memory"
What does it mean by dynamics memory?
I'm running on Window XP Professional Service Pack 3, Intel Core2Quad 2.66 GHz, 3.25 GB DDR3 RAM.
Later on after i delete the volume mesh that partially created before the meshing process halt, i try again with the same settings. This time several faces contained highly skewed elements and 1 of the faces got error msg saying "Triangle surface meshing of face xxx failed", the whole meshing process was then terminated. I thought i already meshed all the faces, why it still need to mesh faces again when i mesh the volume? I have no idea how can i make the volume meshing workable on my model.
I need consultation, please !!!
Another thing, i was told with 2GB RAM, Gambit can mesh 0.5 million elements, then 3GB can mesh 1.8 million. But with the RAM i have now, it still terminate at 0.5M when i mesh a face. Why is that so? Or i've got the wrong message?
khimkhim is offline   Reply With Quote
Old   November 3, 2009, 01:36
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Split your domain, and mesh subvolumes one by one. It will ask less memory
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 4, 2009, 09:36
Ch'ng Huey Khim
How can i split the domain?
Do you mean mesh the volumes before i unite or subtract them?
Old   November 4, 2009, 11:26
-mAx-'s Avatar
Maxime Perelli
no. Before meshing use the split tools
Check the help
memory, mesh volume
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
Simulation of Ahu room flow distribution Donny R Main CFD Forum 0 October 20, 2003 00:40
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
