[GAMBIT] HELP!I have a problem when starting the unsteady iteration |
January 19, 2010, 08:53 |
xuusst
I have a problem when starting the unsteady iteration in Fluent,and it said——"warning:non-positive volumes exist.
Error:divergence detected in AMG solver ressure correction Error object) I guess something wrong with my original grid in Gambit? hELP ME!THANK YOU! |
January 20, 2010, 01:50 |
Maxime Perelli
Rep Power: 41 |
2d or 3d?
if you are working in 2d axi-symetric solver, check out that your domain is in +(xy) plane if 3d, go back to gambit and examine mesh (icone bottom righ). Choose volume and set the min to 1 and the max to 0. It will show you negative volume cells
In memory of my friend Hervé: CFD engineer & freerider |
January 21, 2010, 01:30 |
xuusst
thank you,-mAx-
My condition is in 3D,and i checked the mesh when importing the mesh from Gambit to Fluent,and didn't find negative volume then. I agree with you that there is sth improper in my mesh,but I've no idea how to improve it,now I 'm trying to use the Boundary Layer or Sizefunction to make a better mesh^ And in your reply,I don't understand the sentence your said that"mesh (icone bottom righ). Choose volume and set the min to 1 and the max to 0. It will show you negative volume cells",would you please explain it more simply? Thank you again |
January 21, 2010, 04:04 |
Maxime Perelli
Rep Power: 41 |
http://www.ent.ohiou.edu/~juwt/HTMLS.../tg01.htm#1447
choose Volume type (instead of skewness), then set to lower level to -1 and the upper to 0 Then update ... After importing your mesh in fluent, do a Checkmesh and pay attention to warning regarding negative volume
conditions for unsteady problems | dvdromnu | OpenFOAM Running, Solving & CFD | 5 | November 9, 2009 02:15 |
Force report every iteration in unsteady flow calculation | Friso Landstra | FLUENT | 0 | October 23, 2009 07:13 |
Problem in Reporting Unsteady Particle Fates | Nelson | FLUENT | 0 | August 23, 2006 20:24 |
steady and unsteady Euler eq problem | AO | Main CFD Forum | 3 | January 27, 2004 16:29 |
Question concerning about unsteady problem.... | ghlee | Main CFD Forum | 6 | October 2, 1998 05:36 |
