[ICEM] How can I set the edge parameters so that they override the part mesh setup?
Old   April 13, 2010, 18:28
Default How can I set the edge parameters so that they override the part mesh setup?
Joshua Counsil
Josh is on a distinguished road
Hi all -
I've managed to create a structured mesh over a blade-to-blade turbine cascade region, shown below. However, I cannot seem to specify the domain as two-dimensional. I use Blocking > Pre-Mesh Params > Edge Params and specify the z-directional edges as two nodes in width (for two-dimensionality).
However, even when I do, I end up with three nodes, as shown in the second picture.
I know this is because the Mesh > Part Mesh Setup is interfering with the results for the following reason. Right now, my max size for all the parameters is 5 mm. However, when I change it to 10 mm, the z-directional edges have only two nodes, like I specified!
I know I could avoid using the Part Mesh Setup, but I need it as I want an inflated boundary layer on the turbine blades.
Is there anyway to use both and still have a two-node (i.e. two-dimensional) thickness?
Josh is offline   Reply With Quote
Old   April 16, 2010, 13:33
PSYMN's Avatar
Simon Pereira
Hexa blocking is a separate layer... It should only check the parameters you set on the geometry when you first ask it to update the sizes... After that, interactively set edge parameters rule... However, if you go back and "Update Sizes" again, it will go and check the geometry and reset the sizes on the edges... Is that what is happening?
You should only use the "Update Sizes" if you want it to replace all your edge params... Actually, there are options so it can just update the counts or the distribution if you don't want a complete update...
Simon
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
Structured mesh of a 3d sharp trailing edge Gilles Main CFD Forum 2 May 23, 2008 13:23
Set a set of circular initial conditions on a mesh jinwon park Main CFD Forum 0 January 26, 2008 11:10
