May 10, 2010, 12:21 |
Creating Simple Geometry
Patrick Young
I'm new to CFD and need to create a mesh in ICEM. The geometry that I need to create is quite simple. I need to create a rectangular prism with a relatively small cylinder inside running parallel to the long edge of the prism.
Could someone explain to me how to do this or direct me towards a tutorial? Everything that I can find about ICEM does not use ICEM itself to create geometries, but that is something that I need to do. Thanks! |
June 8, 2010, 20:26 |
Geometry steps.
Simon Pereira
Rep Power: 47 |
ICEM is a surface based modeler, so you build up geometries from entities.
in this case, you would start with 3 points from coordinates... The first would be the middle of the circle, the second, a point on the radius and the third would establish the plane... So maybe 0 0 0, 0 1 0 and 1 0 0. Then create a circle with these three points. Pick the center first, then the point on the radius and then the point in the plane. This would give an R=1 circle. Then create 4 more points. Lets imagine at -20 -20 0, -20 20 0, 80 -20 0 and 80 20 0. Then create curves and pick each pair of points. This would create a box 100 units long by 40 units tall. Then to create the extrude depth, create a point in Z, such as 0 0 50. Then use the surface create tools to extrude by a vector... Select the center of the circle and select the 0 0 50 point, then select all the curves. They will be extruded by the vector (0 0 50) to create the geometry. Then create surfaces from 2 to 4 curves and select the 4 curves on either side of the box to close it in. Build topology (or modify surface => segment with a curve) to cut the sides of the box with the circles. Finally, delete the round sides of the cylinder (assuming you don't want a solid material in the cylinder). It is pretty easy for simple stuff, but not as flexible as more advanced CAD tools. |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
Importing CAD geometry and Editing edges to match | Ahmed | CFX | 15 | March 21, 2016 12:39 |
Meshing on simple geometry | pukiwawa | FLUENT | 5 | August 31, 2008 12:04 |
Creating 3D Elbow Geometry in GAMBIT | Shubha | FLUENT | 3 | June 2, 2008 11:28 |
creating geometry in CFX5.5 | adam | CFX | 5 | July 17, 2002 09:55 |
