[GAMBIT] problem in importing Pro Engineer geometry :-( |
June 11, 2010, 09:26 |
Arash
Dear all,
I am trying to use gambit in order to mesh my geometry which is a bald of wind turbine. I design that blade in ProEngineer 3 and i wanted to import this file from gambit. You can see the blade figure in attachment. The problem is gambit import only the part that created with "extrude tool", and it does not import the surfaces (which connect root to tip) . I also attached the figure of this problem. it would be very very kind of you if you help me in this matter. Thanks a lot |
June 11, 2010, 11:25 |
Chris
What are you saving it as with pro-e? With solidworks, I save the part as a parasolid, and that usually works.
June 14, 2010, 02:06 |
Maxime Perelli
Rep Power: 41 |
I also import ProE (wildfire 3) within Gambit.
I choose Step file export, and I don't have any problem
In memory of my friend Hervé: CFD engineer & freerider |
Problem importing solidworks to gambit | holyo | ANSYS Meshing & Geometry | 3 | April 16, 2010 05:16 |
[Gmsh] Problem meshing an imported geometry | Alicia | OpenFOAM Meshing & Mesh Conversion | 0 | March 30, 2010 04:53 |
[ICEM] Problem in geometry creation by script | lavoz | ANSYS Meshing & Geometry | 4 | March 12, 2010 10:56 |
problem geometry in 2-d | thanos | FLUENT | 0 | November 24, 2009 12:22 |
Geometry setup for phase change problem | Fred G. Kang | Main CFD Forum | 1 | October 14, 1998 11:41 |
