[DesignModeler] Static Ansys (Ansys)
Old   February 4, 2011, 07:23
Post Static Ansys (Ansys)
Mohamed
Malyahya is on a distinguished road
Hi, I am simulating centrifugal compressor flow and vibration, I finished the aerodynamic part, but when i tried to simulate the structural part using (static structural ANSYS), i got an error while updating model, which says (unable to attach geometry).
Appreciate any advise.
Malyahya is offline   Reply With Quote
Old   February 5, 2011, 14:02
Default Time for Tech Support?
PSYMN's Avatar
Simon Pereira
That is a good question for Tech support. They may want to see your model. Academics also qualify for tech support. Send your model to Techsupp@ansys.com or go in thru the customer portal (faster).
Old   February 5, 2011, 18:25
Thumbs up
Mohamed
Thanks, for your advise, I managed to solve the problem by editing the model in the Design Modeler (although a tick mark exits) and saving it again (normally not required).
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 04:24
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 13:39
fprint problem MASOUD Fluent UDF and Scheme Programming 5 October 30, 2011 16:08
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 00:49
