[ICEM] Rotational periodicy setup
Old   April 30, 2011, 07:55
Default Rotational periodicy setup
Procyon
Procyon is on a distinguished road
Heyho everyone,
this might be a stupid question but I have no success in setting up a preiodicy. Even a very simple test case does not work:
  1. I created an empty project
  2. Geometry, create points:
    for the rotational axis (X)
    0, 0, 0
    200, 0, 0
    for the first rotational periodicy surface (from axis to Y)
    0, 100, 0
    200, 100, 0
    for the second rotational periodicy surface (from axis to Z)
    0, 0, 100
    200, 0, 100
  3. Geometry, create curves: one axis curve, two parallel to the axis curve (moved to Y and Z, respectively), two arcs, 4 from axis start/end to the parallel curves
  4. Geometry, create surfaces: one inlet, one outlet, one wall, two periodic surfaces (just a quarter of a pipe ...)
  5. Build diagnostic topology with inherit part turned on, method: all parts
    Output:
    24 vertices merged, merge tol = 0.100000
    0 curves concatenated
    0 curves merged
    0 points created intersecting curves
    0 edges concatenated
    0 surfaces merged
  6. define rotational periodicity:
    user defined by angle
    base: 0 0 0
    axis: 1 0 0 ( in x direction)
    angle: 90 (unit is degrees?)
  7. compute surface mesh with autosizing
  8. edit mesh / check mesh
    only periodic problems checked
    elements to check: all
    Output: There is no periodicity defined in the mesh
What have I done wrong? The same happens if I create a material point in the volume.
Please don't tell me to "read the help/do the tutorials". I read the help, and I will read it again if you point me to the right help page. I have only found two ICEM tutorials in the Ansys customer center, but they don't address my problems.
In this thread: http://www.cfd-online.com/Forums/mai...city-icem.html I read that the periodic faces have to be in the same part, but this is true for my test case.
Bye,
Procyon
Procyon is offline   Reply With Quote
icem, periodicity, rotational
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
How I can setup Fluent for a Define_Profile on FZ? Nuno FLUENT 5 February 23, 2012 03:39
FLUENT 12 cylindrical subdomain setup aerospain FLUENT 0 October 29, 2010 19:10
max rotational velocity of VAWT by CFD CFD-beginner Main CFD Forum 0 April 4, 2010 23:04
setup vof test problem Fang Jin FLUENT 1 June 14, 2005 08:27
