May 2, 2011, 07:25 |
How to block this geometry?
Rep Power: 15 |
Hey guys,
I really need help blocking this inlet. The fluid (air) enters the part from the back. I'm not sure how to block this geometry to get a proper result. It would be nice if you could tell me how to cut the blocks. Thanks in advance! |
May 2, 2011, 07:49 |
Lorenzo Mazzei
Rep Power: 15 |
two blocks could be sufficient in my humble opinion.
May 3, 2011, 03:07 |
Rep Power: 15 |
Thanks for you answer.
I still have another problem with that kind of blocking: the face between the orange and the yellow line always gets associated to the following geometry/blocks with follow this part of geometry. I dont seem to be able to handle that. |
May 3, 2011, 03:37 |
Rep Power: 17 |
you can disassociate that face if you wanted to do so by going to - Blocking --> Edit associations --> Disassociate from geometry and then select the faces to disassociate
Best regards, Santhosh. |
[ICEM] O-grid around wing geometry | Anorky | ANSYS Meshing & Geometry | 15 | November 27, 2017 13:43 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
block geometry inside fluid domain | jeff | Main CFD Forum | 18 | April 12, 2004 11:37 |
