[ICEM] How to block this geometry?
Old   May 2, 2011, 07:25
Default How to block this geometry?
bash0r is on a distinguished road
Hey guys,
I really need help blocking this inlet.
The fluid (air) enters the part from the back.
I'm not sure how to block this geometry to get a proper result.
It would be nice if you could tell me how to cut the blocks.
Thanks in advance!
bash0r is offline   Reply With Quote
Old   May 2, 2011, 07:49
Lorenzo Mazzei
Mazze[ITA] is on a distinguished road
two blocks could be sufficient in my humble opinion.
Mazze[ITA] is offline   Reply With Quote
Old   May 3, 2011, 03:07
Thanks for you answer.
I still have another problem with that kind of blocking:
the face between the orange and the yellow line always gets associated to the following geometry/blocks with follow this part of geometry.
I dont seem to be able to handle that.
Old   May 3, 2011, 03:37
saisanthoshm88 is on a distinguished road
you can disassociate that face if you wanted to do so by going to - Blocking --> Edit associations --> Disassociate from geometry and then select the faces to disassociate
Best regards,
Santhosh.
saisanthoshm88 is offline   Reply With Quote
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 13:43
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 02:58
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
block geometry inside fluid domain jeff Main CFD Forum 18 April 12, 2004 11:37
