[TurboGrid] question on bladegen-data import wizard
Old   January 30, 2014, 08:49
Default question on bladegen-data import wizard
lauda
lauda is on a distinguished road
Hi there,
I'm trying to import an IGS radial turbine geometry in turbogrid. Searching on the web I found that a good way would be to use data import wizard in bladegen. The process guides the user to select the hub and shroud curves and blade object. I follow the steps until I reach step3 (Edit/Confirm Meridional). I check hub and shroud curves (not only in the meridional plane) and it looks fine so I believe there's need to edit. However I can't proceed to step 4 (blade geometry) since I can't "confirm". I'm not sure what I do wrong, if anyone could help I would appreciate, thanks
lauda is offline   Reply With Quote
studying a valve case mina.basta OpenFOAM 33 August 30, 2013 04:46
Import validation data to CFX Post Vattenkraft CFX 0 November 26, 2009 19:55
Problem of import fluent data to ilight fieldview seasoul FLUENT 3 September 9, 2008 22:36
radial turbine data export question ally CFX 0 September 14, 2005 15:10
I-DEAS CAD data import with boundary conditions Yunus Siemens 1 June 1, 2001 10:04
