[ICEM] Setting the BCs
Old   July 12, 2011, 06:56
Post Setting the BCs
Gomatam Sreekar
sreekargomatam is on a distinguished road
Hi, I'm using ICEM for mesh generation and Fluent as the flow solver. During post processing, I'm unable to create the exact planes in which I want to visualize the results in FLUENT. The data sets are very large to be exported to another software. So, is it possible to create those planes in ICEM and use them for post processing in FLUENT??? If so, what should be the BCs of those planes???
Thanks in advance.
sreekargomatam is offline   Reply With Quote
Old   July 12, 2011, 19:28
la7low is on a distinguished road
you could create those surfaces in Icem and set them internal walls in part mesh setup (if you are using unstructured methods: octree etc.), then select interior for those surfaces in BCs selection menu. Then when you export the mesh to Fluent you will have those surface as interiors.
(Please note that those surfaces will have mesh on them, unlike in Fluent when you just create a cut the values are interpolated from neighbouring cells.)
la7low is offline   Reply With Quote
bcs, fluent, icem
Dealing with BC's in OF 1.6 vkrastev OpenFOAM Running, Solving & CFD 5 September 4, 2012 11:58
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
problem in setting up BC's san FLUENT 0 April 26, 2006 01:34
Ultra high temperature? bk Siemens 2 July 19, 2005 00:01
Warning 097- AB Siemens 6 November 15, 2004 04:41
