[DesignModeler] Newbie - Create Region
Old   March 12, 2012, 08:00
Default Newbie - Create Region
Rodrigo Vernini
5746085 is on a distinguished road
Hi, i'm modeling a ultrasonic sensor, because of it's complexity and my affinity with solidworks i decided to design it in solidworks and import to ansys simulation - version 11 (that's installed in the university PC).
I need to make it work in an air region. I saw the function to create a region in the modeler, and i use it when simulating in MAXWELL 3D, but in the simulation screen i can't define the region.
Than i tried to make it in solidworks, creating a part to make it air material, but i need to create a part in the complex area inside and outside the sensor, and i think it's not the easiest way. And all the modification i'll make in the construction i have to make it in this region part.
Than i tried to import the solidworks construction in the modeler instead of the simulation, but i got an error "Geometry interface not found", i saw in the forum that's a license issue.
Someone know a simple way to solve my problem?
Thanks!
5746085 is offline   Reply With Quote
Old   March 12, 2012, 12:15
Rodrigo Vernini
Ok,
no one replied. Don't know if it's because my poor english, the lack of information, or , propably the to newbie question.
The product i'm trying to design is a piezoelectric sensor that must get information about the vibration of a pipe around 40kHz, the vibration will pass through a waveguide that is in touch with the pipe, and will vibrate the air inside a small area inside the product, that contains the piezoelectric sensor. I need to design the product so i maximize the sensibility in the piezoelectric.
I was trying to make this simulation with "modal analysis" but i don't know if a must use CFX or fluent, or any other, because i need that FSI between waveguide-air-piezoelectric.
Please help me, any information will save me a lot of time.
Old   March 12, 2012, 13:15
Rodrigo Vernini
Create Region Solved.
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 14:18
multi region case - access field from another region mabinty OpenFOAM Programming & Development 3 September 6, 2011 10:25
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 09:03
[GAMBIT] Periodic BC truffaldino ANSYS Meshing & Geometry 4 June 5, 2011 06:39
reconstructpar -region borrbyper OpenFOAM Bugs 2 April 23, 2009 13:52
