[GAMBIT] F1 Front Wing Meshing
Old   April 2, 2012, 20:31
Default F1 Front Wing Meshing
Andy
andyjo22 is on a distinguished road
I am having a few issues meshing this F1 front wing in Gambit particularly at the transition point from the centre section to larger main element. I am getting two largely skewed (>0.97) tri's. Is this likely to be an issue with the geometry or meshing scheme.
I am using an unstructured box mesh immediately around the wing and the rest of the domain is a structured quad volume.
Any Suggestions?
Cheers
andyjo22 is offline   Reply With Quote
Old   April 3, 2012, 01:00
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
can you post picture from your mesh and another one with a zoom of skewed elements
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   April 3, 2012, 03:49
Andy
I can certainly post a picture when I get access in about 30 minutes. I can't locate the skewed cells however. Is there a way in Gambit to do this?
Old   April 3, 2012, 03:54
-mAx-'s Avatar
Maxime Perelli
yes.
Go to examine mesh (bottom right), and then in range you give the lower value (0.9 for instance).
If upper limit is 1, gambit will display all cells withi skewness between 0.9 and 1.
Or you can also enable "worst element" option, gambit will automatically zoom on worst element
[snappyHexMesh] Meshing 3D wing (hydrofoil) fails klausb OpenFOAM Meshing & Mesh Conversion 0 December 28, 2011 14:26
Wing Meshing steve1 ANSYS Meshing & Geometry 1 July 5, 2011 09:14
Wing meshing help...... ACER Main CFD Forum 0 January 31, 2011 18:20
Meshing for 3D wing with tubercle on the leading edge in GAMBIT nvtrieu FLUENT 0 August 14, 2010 10:13
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
