Home > Forums > Software User Forums > ANSYS
Does Ansys give real Lift values for model?
Old   May 6, 2013, 15:27
Default Does Ansys give real Lift values for model?
C_K
Myron
C_K is on a distinguished road
I am simulating an aircraft but the problem is the lift force in newtons is half what it would take to lift the aircraft in real life.
However the cl value is fairly realistic.
My question is does ansys fluent correctly give the lift force value or is that just used to calculate cl and my cl and cd numbers are good and thats all im after really.
Any help will be appreciated.
C_K is offline   Reply With Quote
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 05:52
Ansys FLUENT UDF - Velocity profile (of known values) across edge / surface emmkell Fluent UDF and Scheme Programming 2 October 21, 2011 13:12
Ansys FLUENT UDF - Velocity profile (of known values) across edge / surface emmkell FLUENT 0 October 20, 2011 07:37
[ANSYS Meshing] Give me some simple formula for to calculate min & max size values using scaling pandu ANSYS Meshing & Geometry 2 June 6, 2011 11:35
Optimizing UDF Code Cebeci FLUENT 18 September 6, 2003 03:40
