Sergio Contreras
Rep Power: 10 ![]() |
Hi!
I have an error in ANSYS workbench at fluid flow (fluent). When I start Simulation (Transient or Stationary), happens this : First error : Error: Cortex received a fatal signal (unrecognized signal). Error Object: () Then start the simulation again without problems, but throw this message previously: Error: cx-enable-item: wta[1](Widget) Error Object: #f Finaly , when the calculation finish without problems, or when I stop it, second Error: Error: cx-show-item: wta[1](Widget) Error Object: #f Pleeeeees, what do I do for solve this error? Thanks PD: I do not know what to do, because this happens only for some models. The same model, does not deliver said error, but if you change it of folder, then the error appear. It also does in old models that used to work well It's strange |
Mehak
This error occurres when you don't had define the UDF
Sent from my ASUS_Z00LD using CFD Online Forum mobile app |
Patel Brijesh
My project on shell and tube type condenser. In simularion choose Eulerian two phase model with k-e turbulent model. For cold water inlet give mass flow rate inlet condition and pressure outlet. Hot fluid also give mass flow inlet and pressure outlet condition. Here in condenser inlet and inside vacuum pressure so , at inlet given initial gauge pressure given -91000pa and outlet gauge pressure given -95000pa.
When I start Simulation (steady state), happens this :<br /> <br /> First error :<br /> Error: Cortex received a fatal signal (unrecognized signal). Error Object: () Then start the simulation again without problems, but throw this message previously: Error: cx-enable-item: wta[1](Widget) Error Object: #f Finaly , when the calculation finish without problems, or when I stop it, second Error: Error: cx-show-item: wta[1](Widget) Error Object: # Please give some suggestion..thank you. Sent from my Lenovo A7020a48 using CFD Online Forum mobile app |
Display Modes | |
Using ANSYS Fluent 18.0 on workstations with multiple network cards and PBS Pro | cheezum | Hardware | 0 | February 28, 2017 10:23 |
How to combine ANSYS Fluent and Structural analysis? | diwakar | ANSYS | 2 | June 18, 2015 12:07 |
ANSYS and ANSYS Fluent | Field85 | ANSYS | 3 | May 17, 2015 16:21 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
Fluent & Ansys FSI architecture help | DillonS | FLUENT | 1 | April 7, 2010 16:00 |
