transfer mesh from ansys workbench to maxwell
Old   February 18, 2015, 06:45
Default transfer mesh from ansys workbench to maxwell
david
davidsve is on a distinguished road
hi all
i am doing analysis of static magnets using ansys 14.5 and Maxwell 16 using ansys workbench. i want to be able to make the mesh using the ansys work bench mesher instead of using the adaptive mesh of mesh operations that Maxwell provides. it will help alot if someone can explain to me how to import mesh from ansys mesher to Maxwell
thank you all!
davidsve is offline   Reply With Quote
Old   January 31, 2018, 03:20
thomas_cold is on a distinguished road
I'd be interested in this too,
because I'm meshing in Maxwell right now, but it only uses 1 core, even though I've got more than one body.
I found many articles about parallel meshing in Ansys but not quite anything about parallel meshing in Maxwell.
thomas_cold is offline   Reply With Quote
Old   June 11, 2018, 03:42
Default core selection
kamran
kamiphy is on a distinguished road
in maxwell go to tools bar then options, in option tab you will find all available design geometries, you have to select your desired 1D, 2D, 3D, and click. after click you will see the core selection procedure. good luck
kamiphy is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ANSYS Meshing] Output Ansys WorkBench mesh information KiiiKi ANSYS Meshing & Geometry 0 September 17, 2014 10:42
[ANSYS Meshing] ANSYS mesh - I was surprised... assafwei ANSYS Meshing & Geometry 0 September 4, 2014 12:17
importing mesh from Gambit and other software to ansys workbench mortazavi CFX 12 May 30, 2012 07:38
