[Sponsors] | |||||
Damian
Rep Power: 0 ![]() |
Hi there,
I am trying to implement macro to APDL Structural thermal that will find for min/max temperature in particular part. I have done mesh in the way that each volume has ID number (1500, 1501, etc). So I want to know what is the min and max temperature in particular ID part (below example for ID=1500), and for which node number this value belongs to. I tried like this: /POST1 ESEL,S,TYPE,,1500 NSLE,S,ALL *VGET,TEMPS,NODE,ALL,BFE,TEMP but there is an error in script: SELECT FOR ITEM=TYPE COMPONENT= IN RANGE 1500 TO 1500 STEP 1 3654 ELEMENTS (OF 42357 DEFINED) SELECTED BY ESEL COMMAND. SELECT ALL NODES HAVING ANY ELEMENT IN ELEMENT SET. 1017 NODES (OF 25090 DEFINED) SELECTED FROM 3654 SELECTED ELEMENTS BY NSLE COMMAND. *** WARNING *** CP = 19.609 TIME= 19:41:09 Node 0 of *GET command is undefined. Line= *GET, TEMPS, NODE, ALL, TEMP, The *GET command is ignored. Can you please help me out ? |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| chtMultiRegionSimpleFoam: Thermal Conduction + Surface-To-Surface Radiation | Zeppo | OpenFOAM Running, Solving & CFD | 16 | May 18, 2017 19:04 |
| [ICEM] Expanding and constant node distribution | siw | ANSYS Meshing & Geometry | 2 | February 4, 2013 14:47 |
| XY plots big difference node and face values (thermal boundary layer) | TfG | FLUENT | 0 | May 14, 2009 10:02 |
| Short Course: Computational Thermal Analysis | Dean S. Schrage | Main CFD Forum | 11 | September 27, 2000 18:46 |
| Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 11:18 |
