Home > Forums > Software User Forums > ANSYS
ERROR: (DP 18) Update of the Geometry component in Coarser mesh for Design Point 18 f
Old   March 6, 2022, 19:11
Default ERROR: (DP 18) Update of the Geometry component in Coarser mesh for Design Point 18 f
Gerard
gerardsoldevilla99 is on a distinguished road
ERROR in Response Surface Optimization: "(DP 18) Update of the Geometry component in Coarser mesh for Design Point 18 failed: Ya se agregó un elemento con la misma clave."
Hi everybody. I ask for help or any idea on how to solve this problem. I am running a simulation of a certain geometry, which is not important for understanding the problem. The simulation is taking place with CFX. I ran the simulation with no problems. Then I needed to create an optimization experiment, so I added a response Surface Optimization component to the project schematic.
For the first part "Design of Experiment" I created multiple sets of input parameters (different design points) and I clicked to update in order to start computing them. Then is when several error messages appeaed:
I tried to clear the list of design points and even delete the entire block of Response Surface Optimization, but it didn't.
The second part of the error message is written in spanish for some reason, which means:
Ya se agregó un elemento con la misma clave ----- An element with the same code has been already added
Any idea or suggestion will be highly appreciated, or just ask something, so I can give you a bit more info to solve it. Thank you in advance
Gerard Soldevilla
gerardsoldevilla99 is offline   Reply With Quote
OpenFOAM extended 4.0 Error with Multinode Set-up Liweix OpenFOAM Running, Solving & CFD 1 February 18, 2020 00:50
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh czhongrong OpenFOAM Meshing & Mesh Conversion 1 January 20, 2016 05:26
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
