Zones selected for stitch are not in the same object.
Old   October 24, 2021, 17:02
Default Zones selected for stitch are not in the same object.
Svetlana Tkachenko
Светлана is on a distinguished road
Imported CAD of a solid plate between two fluid domains (they are not completely flat, it is a heat exchanger). They are touching. Created geometry in ansys spaceclaim. Started meshing in fluent meshing. Fluent meshing gives the following error:
Error: Zones selected for stitch are not in the same object. Error Object: #f
How can I work around this?
Svetlana
Светлана is offline   Reply With Quote
Old   August 24, 2022, 12:42
Trupen
Trupen is on a distinguished road
Just in case if somebody gets the same error and happen to come around to this post - All your "solids" or "solid+fluid" should be under the same part. To do this, go to designmodeller, select all the solids, than right-click and "Form new part". This would solve the problem with this error in Fluent meshing.
Trupen is offline   Reply With Quote
interFoam and scalarTransport function object with fvOptions sources fusij OpenFOAM Running, Solving & CFD 4 April 18, 2022 07:12
fluent error gui-domain-label: no domain selected Error Object: 1038410352 Fari87 FLUENT 6 January 31, 2021 23:57
[ANSYS Meshing] Is it possible to generate mesh in different cell zones in Ansys meshing? aja1345 ANSYS Meshing & Geometry 0 October 3, 2018 14:22
[TUTORIAL] Implementing porous zones to PisoFOAM ssss OpenFOAM Programming & Development 6 July 31, 2018 14:23
values take by probes function object zfaraday OpenFOAM Post-Processing 0 July 7, 2014 11:06
