Home > Forums > Software User Forums > ANSYS
udf fluent
Old   March 28, 2023, 11:05
Question udf fluent
vahid
vahid7333 is on a distinguished road
Hello friends I use the cracked Fluent fuel cell module on Windows 7, but after a short time, the udfs do not work properly and I have to use a higher version, but I can't do it anymore. In your opinion, where does the problem come from?
vahid7333 is offline   Reply With Quote
Old   March 28, 2023, 20:35
Bin Hao
Bin Hao is on a distinguished road
would you please give us more details?
Bin Hao is offline   Reply With Quote
Old   March 29, 2023, 04:09
vahid
Now I am using the 2021 r2 version with a crack in Windows 7 64 bit. When I use it for the first time, the concentrations change correctly, but after that, these source terms do not work and the concentration does not change. I tried to install the module by copying the addon address. I open the function and manage sections in user define, but it gives me the udf library error. It may be due to not installing a side program like microsoft.net, a special version of microsoft c++, or it is for a crack. Thank you for your answer.
Old   March 29, 2023, 21:36
Bin Hao
I suggeste that you can try to reinstall the Fluent on windows 10 or 11.
fluent
FLUENT UDF for parallelization Cooper24 FLUENT 0 August 27, 2021 11:55
Fluent UDF for moving laser heating of a solid block Cooper24 Fluent UDF and Scheme Programming 7 July 9, 2021 05:56
Problem running fluent with udf on batch tobi b. Fluent UDF and Scheme Programming 3 April 14, 2016 13:54
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 10:16
