Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Very low steam fraction RPI boiling
Prev Previous Post   Next Post Next
Old   May 26, 2023, 10:23
Default Very low steam fraction RPI boiling
Pierre LECHEVALIER
PierreLCV is on a distinguished road
Dear All,
I am currently working on my first CFD boiling simulation using RPI model and I face an issue I can not fix. I have started with a very straightforward steady state situation, vertical tube 20mm diameter and 2000mm length. Water inlet at the bottom at 20°C, 1 bar and 1m/s.
I have imposed a heat flux on the wall which i increase gradually simulation after simulation. It appears that the monophasic situation works very well. I activate the multiphase model when the temperature on the wall is about to reach the saturation temperature and that's where the problem start. Indeed, whatever the heat flux imposed, the steam volume fraction remains very low (i can not reach more than e-5). I have tried to increase a lot the heat flux but the solver diverge then...
Briefly, my simulation is working very well in monophasic state (even when the multiphase option is activated when the heat flux is low enough) but when the heat flux is high enough to create steam, the fraction remains very low whatever the flux.
As it is my first RPI boiling simulation, i am using the "default" values for all the RPI model parameters adviced by Fluent Manual.
I precise that I have activated the gravity...
Any idea ?
Thank you for your help !
Pierre
PierreLCV is offline   Reply With Quote
Convergence Issue Of RMS Mass Vapour in RPI Boiling Model in CFX nomi.tahir Main CFD Forum 1 May 28, 2018 03:56
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 14:05
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel Mehrez OpenFOAM Running, Solving & CFD 10 May 18, 2016 11:44
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
