Movement of piston in a cylinder with fluent?
Like Tree2Likes
  • 1 Post By Far
  • 1 Post By a.zareinezhad
Old   February 7, 2012, 19:18
Default Movement of piston in a cylinder with fluent?
Andy
Whitworth is on a distinguished road
I'm starting to build a model of a piston (say 45mm diameter, 20mm length) in a sealed cylinder of air (50mm diameter 100mm length). This piston moves up and down (+ and minus y) with a sinusoidal velocity.
At the top of the cylinder there is a constant temperature of say 100 degrees centigrade and at the bottom 25 degrees centigrade. As the piston moves downward, the air is forced to the top of the cylinder, heating up and as the piston moves back upward, the air moves back down to the bottom.
My question is, how would I start to go about modeling this in fluent? I've never modelled something with motion before and a tutorial would be great. The setup in my head would be...
-geometry,cylinder of fluid constructed with a missing pocket 45mmx20mm, representing the piston.
-energy equation enabled so heat transfer was active
-no initial fluid velocity (piston would be at bottom dead center)
-top and bottom zones set at constant temperature
-cylinder wall set to 0 heat flux
-viscous model selected depending on approx reynolds number
But where might I find the options to translate the pocket in the continuum?
Thanks in advance
Whitworth is offline   Reply With Quote
Old   February 10, 2012, 11:03
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Check this link
http://www.cfd-online.com/Forums/ans...ic-engine.html
tsram90 likes this.
Far is offline   Reply With Quote
Old   September 18, 2013, 09:09
Rajendra Kumar
rajendra9424 is on a distinguished road
Thanks in advance
Dear Whitworth,
i have also written UDF for moving wall, but the movement of wall is always +y and reaches in original position y=0 but not in -y direction. so how can i make movement of wall in + to - ?
rajendra9424 is offline   Reply With Quote
Old   September 19, 2013, 12:27
Post Tutorial : Cold Flow Simulation Inside an SI Engine
a.zareinezhad is on a distinguished road
Dear Whitworth & rajendra9424
this file can help any one that want to simulate any kind of cylider
with valve motion and injection!
if you need more help
just call me
download file of Cold Flow Simulation Inside an SI Engine here
or here
amin_gls likes this.
a.zareinezhad is offline   Reply With Quote
Old   March 3, 2015, 10:05
Vivek M
mvinovivek is on a distinguished road
I downloaded the file and tried to run the simulation. but after a certain number of iterations i got an access violation error. how can i rectify that. pls help me . Thanks in Advance
mvinovivek is offline   Reply With Quote
Old   March 3, 2015, 23:50
Default Fluent Access Violation error after a specific iteration number
FLUENT, flow past a circular cylinder Paul Reichl Main CFD Forum 16 December 8, 2012 15:21
A piston movement simulation mohammad CFX 2 January 8, 2012 19:39
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 11:55
simulation of piston motion inside a hydraulic cylinder mosman Main CFD Forum 0 August 7, 2011 01:40
Some help simulating Magnus Force using Fluent Michele Spinolo FLUENT 6 June 27, 2002 12:57
