Extract points from polyline
Old   January 18, 2015, 21:54
Post Extract points from polyline
S. Morichika
Saidul is on a distinguished road
Hello Everybody,
I am trying to extract some points from the inlet surface of my geometry and for this, I draw a ployline on the inlet surface and save the points in a file. Everything is ok but when I used that point to release particle it seems some points are out of domain. Then I draw a polyline in the middle of the inlet surface and extract the point. But after run the simulation, it seems some points are out of domain.
My question is, how can I get that points which are inside the domain. I will be happy to hear from you.
Thanks and regards,
Saeed
Saidul is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 11:27
[General] Extract Points along a polyline AshwaniAssam ParaView 4 May 1, 2014 14:09
CFD-Post: Polyline Export at Integration Points minger ANSYS 4 February 22, 2014 09:23
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
