Downstream droplet size data
Old   December 8, 2004, 05:59
Default Downstream droplet size data
Nick
Im trying to extract droplet size data at three downstream locations in a simulation. Does anyone know how to do this? (or if it is possible)
Old   December 11, 2004, 18:17
Default Re: Downstream droplet size data
Mike
You should try using the user subroutine dravrg.
This subroutine will be called as the Lagrangian tracking progresses, at each step. Be careful not to doublecount parcels. It takes some thoughtful logic to avoid doublecounting.
Alternatively, user support can supply you with a separate code to give you direct access to the track file. From that file you could parse through all the parcels and note their size and count at the locations of interest, and perhaps write these into a log file.
I can get you the program that reads the track file if needed. It works under Linux and possibly other platforms. Just send me an e-mail - mhenneke@adapco.com
first wall layer thickness and droplet size itchie CFX 3 May 14, 2008 09:03
Importance of droplet size Itchie CFX 2 December 13, 2007 02:01
droplet size Neser CFX 1 January 26, 2004 13:42
Automatical resizeure of droplet plot size Marc Siemens 0 June 7, 2002 06:08
Initial droplet size distribution Ossi Kaario Siemens 2 March 13, 2001 12:19
