November 28, 2005, 05:13 |
mass flow rate
Star-CD users!
I have recently solved a problem of complex duct with multiple outlets in Fluent/CFX/Star-CD under identical flow conditions and obtained the convergence of numerical solution in all the solvers. I am very much impressed about flow pattern captured at mid-section of the duct in star-CD over other solvers. In other solvers, I could able to obtain mass flow rates at different outlets by mouse click. I am unable to find the same in star-CD. Can any one suggest a way as how to obtain mass flow rate at different outlets through single command. Towards this I am spending quite lot of time in Star-CD. Dr C.Bhasker |
November 28, 2005, 07:03 |
Re: mass flow rate
I know one way: in PROSTAR, Analysis Control=>Output Controls=>Monitor Numeric Behavior Click Print Iteration Residuals and Conservation Checks, then re-write problem file and run RESTART for one iteration, you can have all the information in .info file.
November 28, 2005, 11:36 |
Re: mass flow rate
go to analysis controls -> Output controls -> monitor engineering behaviour -> monitor boundary behaviour ....
November 29, 2005, 01:36 |
Re: mass flow rate
The hint povided by you works fine and with this required information is available in inf file after its run.
Dr C.Bhasker |
November 29, 2005, 01:34 |
Re: mass flow rate
Thanks! it has provided the required information in info file.
Dr C.Bhasker |
December 20, 2005, 04:08 |
Re: mass flow rate
with "monitoring boundary behaviour" an *.erd will be created with the selected boundary information (e.g. massflow)
With "monitoring cell behaviour" you can get the selected information in any wanted (and previously defined/stored) cell set in the *.ecd file. In main menu "Post" use the "flux summ" command (read help) Load *.pst file, get "Mass Flux" from vector data, generate a cell set and type in the command "summ". |
Mass flow rate of the DPM mass sourse ?? | Rhinocao | FLUENT | 3 | January 21, 2011 12:10 |
Mass Flow Rate!!! | haiduc | FLUENT | 1 | June 7, 2007 10:08 |
DMP mass flow rate | Don Parsons | FLUENT | 3 | April 17, 2007 02:30 |
Mass flux and mass flow rate | us | Phoenics | 10 | March 31, 2006 02:06 |
How are the mass flux and mass flow rate defined? | Miles | Siemens | 2 | November 7, 2002 08:45 |
