"could not bind to local port"
Old   December 20, 2007, 03:14
Default "could not bind to local port"
Frias
Hi guys,
I try to make an air simulation of an ICE using Star-CD 3.26 and a mesh created with es-ice. When I launch STAR:
"could not bind to local port cannot assign requested address"
and stop the simulation (or better, never start!!!)
Please help me
Many thanks
Eddy
Old   December 20, 2007, 04:18
Default Re: "could not bind to local port"
Vinny
If you work on Linux operating system, probably you have an old process "zombie". Use command "ps -ef", and kill the processes where you read PROSTAR or similar. Bye
Old   December 20, 2007, 05:11
Frias
Thanks a lot Vinny,
i 've done what you said but it still didn't work.
what can i do??
Thanks
Old   December 20, 2007, 05:51
Vinny
Mhmhm, try to restart network services and check if rsh is active.
Another try (if you use a workstation) is to restart your pc and suddenly run the calculation. You must be sure you haven't another Ice process. In fact, you can run only one Ice-simulation for each pc. Vinny
Old   December 20, 2007, 05:55
Frias
Now there is a big real problem. When i launch star, in the "top" there are no ICE process!!!!
Why
Very very thanks
Eddy
Old   December 21, 2007, 04:05
Default Now works
Frias
It's a license problem (wrong IP)!!
Thanks for your answers
Eddy
OpenFoam local and local sven82 OpenFOAM Installation 1 December 9, 2008 09:40
Port OpenFOAM to IBM Cell BE mgarcia OpenFOAM Installation 2 November 1, 2007 07:33
Port of OpenFOAM14 to FreeBSD thierry OpenFOAM Installation 0 April 28, 2007 09:36
Suse Linux 91 port hjasak OpenFOAM Installation 23 April 16, 2006 11:13
Linux/Alpha port ? Prateep Chatterjee FLUENT 1 June 5, 2000 21:28
