Increase speed of parallel computation
Old   November 29, 2010, 20:16
Default Increase speed of parallel computation
Purushothama Chippar
Purushothama is on a distinguished road
Dear StarCD colleagues,
I am using starcd 3.26 for fuel cell simulation. We have cluster facility with 48GB server and 8 nodes of 8GB memory each. When I do simulation of large-scale geometry having cells about 4 million with 32 processors, it takes about 4 minutes/iteration. This is too much. I issued the command,
star -dp -mpi=hp -decompmeth=s node0,4 node1,4 etc..
I have also tried with 8 processors, but the time taken per iteration is almost same. I use ufiles and CG solving method.
Is there anyone know how I can reduce simulation time? I have tried with AMG method, but found it is not working well with my ufiles.
Purushothama is offline   Reply With Quote
Old   November 30, 2010, 14:03
TMG
TMG is on a distinguished road
First of all, you might try running on a version of STAR that's not 10 years out of date. Second, its often the case (not always) that your own user subroutines are at fault. If they don't scale, then the solution certainly won't. Finally, you are forcing the decomposition definition yourself by using sets. If that is not an optimum decomposition, then you will not be able to scale to higher numbers of domains.
TMG is offline   Reply With Quote
Old   November 30, 2010, 14:51
Pauli
Pauli is on a distinguished road
"48GB server and 8 nodes of 8GB" ?? My math says 8nodes x 8GB = 64[IMG]file:///home/home-titan/ptroxler/tmp/moz-screenshot.png[/IMG]GB
Are you running on all cores of all nodes? If so, that could also be contributing to lack of scalability. Whether it does or not is problem and cluster configuration dependant.
Have you tried leaving one core "free on each node"? That along with using Metis for decomposition might help performance. That is unless you have a good reason to decompose by sets.
Pauli is offline   Reply With Quote
large-scale, parallel computation
load balancing in parallel computation shyamdsundar Main CFD Forum 0 September 2, 2009 23:53
Errors in parallel computation ILia Skryabin FLUENT 1 January 19, 2007 08:20
how to parallel computation Jane Siemens 2 April 28, 2004 06:11
Parallel computation problem in Tascflow dandy CFX 3 April 21, 2002 00:32
speed up ratio at parallel processing Kim hak-gyu Main CFD Forum 1 October 25, 2000 09:57
