Require Support OpenFoaMultiphase interFoam pipeflow One inlet Two outlets |
January 21, 2020, 04:42 |
Munaf
Rep Power: 6 |
I have a multiphase pipe flow case with one inlet (inlet1), two outlets (outlet1 and outlet2) and one vent shaft (atmosphere) as per screen shot below attached with turbulent flow k-e model enabled
When run the solution and simulate results in preview it shows the flow when reaches outlet 1 and 2 it starts to reverse as if there is wall at these outlets that is preventing the flow to exit you can see the simulation video attached. I really appreciate the help in this one as I believe something wrong with the settings of my boundary conditions as I have tried millions of combinations and options for BC for the last 6motnhs. I have atatched the Case file and screen shots where reverse flow occurs at outlet1 and outlet2 You can get in touch with me on mwmalkawi@hotmail.com |
January 21, 2020, 04:48 |
ssa
Rep Power: 7 |
I would like to try the case in a different openfoam version OF2.4
January 21, 2020, 10:42 |
Munaf
Rep Power: 6 |
Sned me your email address so I can email you the whole case with the mesh
Thanks mwmalkawi@hotmail.com |
February 21, 2020, 08:23 |
Mahmoud Aboukhedr
Rep Power: 12 |
Did you managed to solve your problems,
I already contacted you regarding your other post for multiphase flow simulation, we can also discuss this one if you like. Best, MA |
[swak4Foam] Trouble setting groovyBC interFoam Inlet BC | mgdenno | OpenFOAM Community Contributions | 4 | July 1, 2012 08:16 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Variation of inlet hight in interFoam | deniggo | OpenFOAM | 0 | November 12, 2010 18:39 |
High depression at low alpha inlet (interFoam) | santiagomarquezd | OpenFOAM Running, Solving & CFD | 0 | June 1, 2010 17:18 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
