October 18, 2023, 09:16 |
FLOEFD fan simulation
Hi all,
I am a mechanical engineer approaching FLOEFD software from siemens. I have experience with Ansys mechanical, Catia V5, CREO. I briefly explain the problem. I have a a box with inlet and outlet fans and I am running a flow simulation with the fan curves implemented for each fan. Once the solution is achieved, I can get the fan curves and hence the operating point for each fan. I would like to: 1) Calculate the parallel/series of fan curves according to how the fans are placed (if in parallel or in series) 2)Calculate the system ventilation curve given by the series/parallel obtained in point 1 3) Pressure drop curve of the box 4) Intersection between the two curves (pressure drop curve and system ventilation curve) to see the operating point of the whole system. Is it possibole to get these plots ? Thanks in advance, I hope the problem description is clear. Regards, Alex |
How to represent a fan on a simulation? | igor.leo93 | OpenFOAM Running, Solving & CFD | 4 | June 21, 2022 19:55 |
Residual Divergence Issue In Convective Fan Cooling Simulation | JulianH | STAR-CCM+ | 2 | February 28, 2020 11:52 |
Fan simulation with inlet and outlet duct | chaudhry_hashim | STAR-CCM+ | 0 | June 27, 2014 08:59 |
FAN simulation with inhomgen Temperature | Shark | STAR-CCM+ | 1 | May 8, 2013 09:24 |
Fan simulation divergence | ayothicfd | CFX | 18 | July 20, 2012 05:53 |
