Mesh effecting the convergence
Old   July 3, 2012, 11:16
Default Mesh effecting the convergence
saisanthoshm88 is on a distinguished road
Could some one please suggest me how to check if the high residuals in a CFD simulation are a result of mesh quality problems.
I mean I just want to make all the possible cross checks to confirm if the mesh itself is not causing any convergence problems.
so I request suggestions to be really sure with the kind of mesh being used for the simulation.
I'm particularly refering to the mesh checks to be done in the CFD Post ( may be like creating some IsoVolumes (or) so...) (or) from the .out file but not to the basic quality checks in the mesher itself
Best regards,
Santhosh.
saisanthoshm88 is offline   Reply With Quote
Old   July 3, 2012, 14:49
playmaster
playmaster is on a distinguished road
make different mesh size according to ASME policy, and calculate your target of solution (for example torque value) per each mesh size and draw the chart of targer vs. mesh size. when the slope of that line descends, you can choose the smallest mesh henceforth.
playmaster is offline   Reply With Quote
Old   July 3, 2012, 16:24
I usually use a max. residual of 1e-3 as the convergence target. However outputed to the CFD post is only a distribution of residuals and not the max (or) RMS residuals.
So if I wanted to create IsoVolumes to residuals in CFD post is it fine to choose residuals above the 1e-3 value.
I'm only asking for a kind of analogy between a residual limit set as convergence target and the residual limit above which the residuals have to be looked on in CFD Post from IsoVolumes
Best regards,
Santhosh.
Old   July 3, 2012, 18:56
The max residual is simply the maximum of the residual field and RMS is the RMS of the field. You can use the function calculator in CFD-Post to calculate ths and hopefully it will match the residuals reported in the output file.
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
