Problem with CFX-SOLVER MANAGER
Old   September 12, 2012, 09:51
Default Problem with CFX-SOLVER MANAGER
mariam.sara is on a distinguished road
Hello I am unable to run my .def file in cfx-solver manager when I click start run the following message appear to me:
feature cfx-solver-physics-module does not exit in the ANSYSLI pool
what the problem?
mariam.sara is offline   Reply With Quote
Old   September 12, 2012, 18:52
It cannot find a license to run it. Check the license server is up and that your license has not expired.
Old   September 13, 2012, 01:15
I do not think there is problem with my license it all running i check it from SERVER_ANSLIC_ADMIN UTILITY furthermore i run a tutorial from help its about "Buoyant Flow in a Partitioned Cavity" it work fine and I saw the results with post cfx but I think there is problem with my case settings I depend on a paper its uses ANSYS CFX too I follows its steps of modeling but I do not really know what happen and this error now appear to me : run terminated with errors No result file created?
I can post the paper and my CCL file if you want have a look?
Old   September 13, 2012, 07:06
Do you have a basic CFX license? This only allows the simple physics to be used. If you are asking for physics which requires an optional physics license (eg moving mesh, advanced turbulence, chemistry etc) and it cannot find one it will bomb out, yet run the simple tutorial problems fine.
Old   September 13, 2012, 07:11
But as i know if the license stopped the program cannot be run anymore? The license manager is working?
CFX 11 Solver problem dak56 CFX 3 December 11, 2008 19:20
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
Fan Modelling Problem in CFX Jenny CFX 8 September 11, 2007 13:59
Problem on mesh import to Ansys CFX 10.0 Stephen Lau CFX 1 April 18, 2007 03:02
CFX 5.6 memory problem with solver sreevisakh CFX 3 February 2, 2004 04:57
