exports geometry workbench to ICEM
Old   November 30, 2012, 08:23
Default exports geometry workbench to ICEM
Talles Caio
TallesC is on a distinguished road
hello, I'm trying to export a geometry of a pipe workbench to ICEM, but the centerline of the pipe is not appearing in Icem, I need this line to generate the mesh, I've tried exporting in different types of extension (IGS, Parasolid) but it did not work! please help me?
TallesC is offline   Reply With Quote
Old   December 1, 2012, 04:15
Why do you need the centreline to generate the mesh? This is not normal mesh generation procedure.
Old   December 1, 2012, 11:37
Talles Caio
I need this line to facilitate the creation of the blocks to generate the mesh in Icem, you know if it is possible to export geometry with the central line that was used to make the geometry of the design workbench??
Old   December 1, 2012, 14:50
This question is best asked on the geometry and meshing forum.
I think ICEM has functions to get the centre point of an arc. You can easily regenerate the centreline from that. Would that be adequate?
Old   December 1, 2012, 15:08
Talles Caio
I need to check if the program does this operation, I'm thinking that the center line does not appear in ICEM because this line was created in the design workbench to generate solid, anyway thanks for the tip!
PEM Fuel cell module meshes. ICEM vs workbench aarvay FLUENT 24 March 2, 2020 06:50
[ANSYS Meshing] Simple question.... :) Export ICEM mesh to Workbench Craig ANSYS Meshing & Geometry 4 April 4, 2014 19:25
[ICEM] Meshing adjacent wall geometry and simple ICEM questions everdimension ANSYS Meshing & Geometry 25 June 20, 2012 04:25
[ICEM] Best way to import geometry ICEM Cottbus ANSYS Meshing & Geometry 4 June 12, 2012 09:42
2D geometry in ICEM NITIN DEWANGAN CFX 3 August 21, 2008 17:25
