May 5, 2013, 17:28 |
Back flow in axial comperssor
DEAR SIRS
I NEED TO KNOW THE BEST BOUNDARY CONDITIONS USED IN MODELING OF AXIAL FLOW COMPRESSOR IN ANSYS CFX . IF I USED INLET PRESSURE 1 Pa AND MASS FLOW RATE AT OUTLET =20KG/S THE SOLUTION NOT CONVERGE ???I DO NOT KNOW WHY ?? THE PRESSURE RATIO =2.105 |
May 5, 2013, 18:52 |
Rep Power: 143 |
FAQ: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
And also read the best practises guide for turbomachinery in the CFX documentation. |
May 26, 2013, 08:36 |
#3 | |
May 26, 2013, 09:00 |
Rep Power: 143 |
Usually a mass flow inlet with a pressure outlet is best.
But this is all discussed in the documentation. You really should read it so you know the answers to these questions yourself. |
May 27, 2013, 06:42 |
#5 | |
You can also give the following boundary conditions: Inlet: massflowrate @ 20 kg/s Outlet: Static Pressure Try to put Y+ value correctly as found by the formula. Apply SST turbulence model, if you are not having much experience in CFD. I hope this will improve your convergence. |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Axial velocity problem in 2D axisymmetrical flow | mozkan26 | FLUENT | 19 | April 28, 2013 13:06 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
Surface streamlines on axial flow fans | Jennifer | CFX | 2 | February 17, 2009 14:50 |
Flow visualization vs. Calculated flow patterns | Francisco Saldarriaga | Main CFD Forum | 1 | August 2, 1999 23:18 |
