November 4, 2020, 20:32 |
#21 | |
John Khoo
Rep Power: 13 |
I recently ran into this issue as well.
For anyone looking to Reset their Results file, please remember to save a copy of your .cst file before trying this out as you'll lose all user defined plots, variables and expressions. My Problem: This error occurred for me when Design Modeler modifications I made changed the Contact Region names. This affected CFD-Post (particularly several Streamline and Vector plots that referenced some locations in the domain) in a Fluid Flow (Fluent) Analysis System. I got the following error from Ansys Workbench: CFD-Post Application Error WARNING ISO CLIP: XXXClip Could not locate Domain List entry /DATA READER/CASE:Case FFF/Domain:xxx ERROR No locators provided in Location parameter. Solution that worked for me: I changed the domain that the Iso Clip was referencing from All Domains to All FFF Domains, and recreated the existing Streamline and Vector plots. Happy explorations! Quote:
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
