January 17, 2014, 06:41 |
Monitor points in multiphase flow
Rep Power: 12 |
I am trying to create an expression for an additional variable monitor point.
The expression I have is: volumeInt(Radiation)@Fluid This has been working fine for single phase fluid flow but I would now like to model multiphase and was wondering how to apply this to expression to a specific fluid. Probably simple, I just can't think how to do it. Thanks, Stuart |
January 17, 2014, 07:03 |
JESS
Take a water-air system for example, if u want to monitor the air volume fraction mixing in the tank, u can use volumeAve(air.vf)@Tank.
Similarly, u can use volumeInt(Phase A.Radiation)@REGION in your case. |
March 12, 2014, 09:14 |
Rep Power: 12 |
Thanks for your reply, however I am still having problems with it.
When I enter the expression as you suggested, i.e. volumeInt(Air.Radiation)@Fluid I receive a different error message : The additional variable 'Air.Radiation' referenced in parameter 'Expression Value' in object '/FLOW:Flow Analysis 1/OUTPUT CONTROL/MONITOR OBJECTS/MONITOR POINT:Radiation does not exist in Domain 'Fluid'. |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
multiphase flow ,mass and volume fraction imbalance | sope111 | CFX | 16 | September 3, 2018 00:10 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Multiphase Flow with NIST Real Gas Model | Annka | FLUENT | 7 | May 23, 2017 07:58 |
Capillary pressure in multiphase flow in porous media | Lalit | FLUENT | 0 | March 21, 2013 01:24 |
