April 12, 2016, 11:28 |
How to set Rotational offset In CFX?
Aja
Rep Power: 14 |
I simulated an axial turbine, This turbine includes two stationary frame and one rotating frame as follows: Rotation frame=blade stationary frame=before and after blade I used frozen rotor model. In this case, How do i set rotational offset? Thanks for your guidance. Aja |
April 12, 2016, 11:32 |
Rep Power: 32 |
Edit the definition of the Frozen Rotor interface, and you should see a Rotational Offset parameter to be set.
Hope the above helps, |
April 12, 2016, 11:58 |
#3 | |
Aja
Rep Power: 14 |
But i didn't understood your means completely! because English language is not very good. I am grateful that explain more. When i enable rotational offset, its value is equal to zero. |
April 12, 2016, 12:27 |
Rep Power: 32 |
The default value is 0 [deg]. That is, use the relative configuration as provided by the mesh you imported.
If you set a value different from 0 [deg], the rotor will be moved by such amount, and the relative configuration will change. |
April 12, 2016, 12:52 |
#5 | |
Aja
Rep Power: 14 |
I think that Your means about "configuration " is computational domain. right? According to picture in post 1, I think that rotational offset is eaual to zero. Am i right? |
[ICEM] ICEM Scripting Issues | tylerplowright | ANSYS Meshing & Geometry | 33 | September 27, 2021 16:35 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
hi how to set entironment variable in CFX pre | romance | CFX | 0 | December 23, 2007 07:11 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
