May 17, 2014, 03:07 |
how to play session file????
Hydreaulic structures
Rep Power: 14 |
hi dear all
Where should I go to run the session file? Based tutorial software, launch cfx> select session> play tutorial but i select session , only have new session and play tutorial not available Please advise me Thanking you in anticipation. |
May 19, 2014, 09:24 |
Edmund Singer P.E.
Rep Power: 20 |
You havent saved your session file? Did you even generate one?
May 21, 2014, 10:47 |
Rep Power: 14 |
dear singer1812
hi, i want play session file in tutorial cfx, but basing tutorial cfx, The procedure file has been written : 1. If required, launch ANSYS CFX-Pre. 2. Select Session > Play Tutorial. 3. Select StaticMixer.pre. 4. Click Open. A definition file is written. 5. Select File > Quit. 6. Launch the ANSYS CFX-Solver Manager from CFX Launcher. 7. After the ANSYS CFX-Solver starts, select File > Define Run. 8. Under Definition File, click Browse . 9. Select StaticMixer.def, located in the working directory. 10. Proceed to Obtaining a Solution Using ANSYS CFX-Solver Manager but Not applicable for me, please help me, how to play session file? thanks a lot |
August 18, 2017, 07:41 |
Daniel
Rep Power: 9 |
Because this thread does not have the right answer and I was looking for the "play session" button, too, i would like to answer it for future questions.
To play the tutorials/sessions it is necessary to open CFX Pre NOT over Workbench. Just search in your menu CFX and choose there CFX Pre. At the menu tab "Session" - > "Play Session" you can choose your .pre file! Then save it as .cfx. Afterwards you can select the Case in CFX through Workbench and start the simulation! Have a nice day! |
July 20, 2020, 04:35 |
AnsysUser
Rep Power: 9 |
you need to open cfd post(start menu--> CFD Post) separately to play session file.
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
