June 14, 2014, 17:19 |
CFX Multiphase - Fluid-fluid heat transfer
Nasir Mehmood
Rep Power: 15 |
Dear Experts
I need help and guidance from you. Need to do simulation in CFX. I have a coil and hot air is entering in that coil at 750 K with inlet velocity of 0.2 m/sec and exiting into the atmosphere. That coil is enclosed inside a drum filled with water at 298.15 K, and water is closed inside the cylinder. Need to simulate the heat transfer from coil to water. It may be a simple problem for you all but for me its difficult. What i have done so far in CFX. I made two domains in CFX, one is air and other is water. As both the fluid are separated and not touching each other i am not using homogeneous. What is the mistake i am making ....... plz help CCL file is attached |
June 15, 2014, 06:48 |
Rep Power: 143 |
Please show an image of what you are modelling and any error messages you are getting.
June 15, 2014, 07:04 |
Nasir Mehmood
Rep Power: 15 |
plz see the images of model and mesh
there is no error message but coil is not heating the water |
June 15, 2014, 18:44 |
Rep Power: 143 |
Have you done the tutorial examples - like the heating coil?
Heat Transfer Solid to Fluid [CFX] | skaboy607 | CFX | 15 | January 11, 2021 19:19 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Porous domain:Interfacial area density and heat transfer coefficient | l.te | CFX | 2 | May 17, 2014 23:45 |
Solid / Fluid Heat Transfer | Koranten | FLUENT | 3 | March 19, 2011 07:21 |
multiphase flow heat transfer | yeeking86 | CFX | 1 | April 16, 2009 08:29 |
