local parallel overflow error
Like Tree1Likes
  • 1 Post By ghorrocks
Old   January 24, 2011, 22:02
Default local parallel overflow error
Hamed
enghamed is on a distinguished road
I am simulating a two-phase tank sloshing .
In the solver manager when I define the run if I run it as serial it is fine but if I do a local parallel and partition it, I get overflow error!
Why is this happening? what should I do?
enghamed is offline   Reply With Quote
Old   January 25, 2011, 03:50
Max Efficiency is on a distinguished road
I have got the same problem with a single-phase-simulation including a stage-interface and one interface with rotational periodicty. I helped myself by starting the simulation as a serial simulation. After a few iteration I stopped the simulation and then started it again with the parallel option activated.
But of course, I am also very interested in the reason that is responsible for that error. If I remember correct, the error messages says, that there is not enough memory available. In my case memory allocated was about 500 megabyte and later on the solver asked for about 10 gigabyte...
Max Efficiency is offline   Reply With Quote
Old   January 25, 2011, 05:08
Hamed
I tried running first as serial and after stopping making it prallel but it didn't work for me.
I dont get memory error, i beleive I have enough memory, but I get overflow error when its parallel.
Old   July 12, 2014, 06:45
Default Same problem
armlic is on a distinguished road
Hello enghamed,
Did you ended up figuring out your problem????
Which was the cause of your overflow? I´m interested to know, I may have the same problem.
armlic is offline   Reply With Quote
Old   July 13, 2014, 07:34
This happens a very small amount of the time. The usual cause is a free surface or some other high gradient thing (eg shock wave) aligned with a partition boundary. The usual fix is to use a different partitioning algorithm to move the boundaries to somewhere with more gentle gradients.
tkz likes this.
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 05:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
