August 18, 2014, 02:57 |
Two-way FSI error
Yangmeng
Rep Power: 11 |
I follow all the Tutorial21 steps completely to simulate a Two-way FSI model of a valve of shock absorber, but it CFX can not solve and shows this message:
+--------------------------------------------------------------------+ | ERROR #002100061 has occurred in subroutine SERVE_CLIENTS. | | Message: | | The connection between this CFX process and an external process | | has died unexpectedly. The following error was received: | | External process : ANSYS | | Error experienced : Read | | | | ** This error is fatal: Terminating ANSYS CFX Solver execution ** | | Please review the output, error and log files from both the CFX | | and external processes to determine the cause of the error. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created can any body help me with this? Thanks! |
August 19, 2014, 04:35 |
Matthias Voß
Rep Power: 20 |
ANSYS crashed, check the *.err-file in the run-directory of the case.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 08:43 |
