CFX pre error in assigning material to the domains
Old   February 18, 2015, 01:10
Post CFX pre error in assigning material to the domains
Madan Mohan
madan is on a distinguished road
I am doing a numerical simulation in CFX about the turbine nozzle blade, where I am using a cooling passage inside the blade periphery. The cooling method is rib-turbulated cooling for the turbine blade. But I am getting the problem while assigning the material for the domains in CFX-pre. I have two domains namely Gas and Coolant. The gas domain which has the material properties of ideal gas at 1200 K and the coolant domain has the material properties of ideal gas at 700 K. I have created two materials separately and tried to assign the material for the domains. If I assign gas for a domain the same is getting assigned for the another domain. For eg, If I assign gas as the material for the Gas domain it is getting automatically assigned for the Coolant domain also. Even though if I am changing the material for the another(Coolant) domain it affects the current(Gas) domain also. Please help me out from this problem. I am new to simulation field so I am not that much familiar with all the options in CFX. I am using CFX 5 for the simulation of the problem
Thanks,
Regards,
Madan
madan is offline   Reply With Quote
Old   February 18, 2015, 01:55
Opaque will become famous soon enough
http://www.cfd-online.com/Forums/cfx...-material.html
Opaque is offline   Reply With Quote
cfx 14.5, material error
only 1 of many named selections not showing up in cfx pre mihirbhagat CFX 2 April 26, 2019 04:56
Adding new fluid material in workbench and using it in cfx nirajpandya ANSYS 1 May 7, 2014 05:35
[ICEM] Using a ICEM mesh with multiple Domains in CFX without Domain Interfaces ChristianF ANSYS Meshing & Geometry 0 January 24, 2012 05:51
CFX 5.7.1 PRE and solver won't start daniel CFX 1 January 20, 2006 10:09
CFX 5.7 pre Neser CFX 0 January 27, 2005 11:22
