How can i assign a set of data (table or matrix) as an input for source term? |
March 2, 2015, 06:07 |
Rep Power: 11 |
Hi
I am simulating a channel flow in cfx and i need to add source term to continuity equation.in order to add mass source term i need to set its temperature.instead of assigning a constant temperature value for whole domain, i want to use a set of temperature values (like a temerature matrix) over my domain. my question is: is it possible in cfx to assign a set of data as an input instead of a fix value or an expression? How can i do it? I am new to cfx so please help me. thanks in advance. |
March 2, 2015, 08:48 |
Edmund Singer P.E.
Rep Power: 20 |
Look up tables or functions. These are pretty easy to use, and you can even import a file with the values you want to use.
If you have further questions after reading up, please ask. |
March 2, 2015, 09:59 |
Rep Power: 11 |
thanks singer1812 for taking your time and answering my question. I did as you said and looked up cfx document under user functions. as you said ,I can create a set of data including coordinates and quantity of interest and cfx will use interpolation to calculate values on nodes.
you said i can import file containing values i want, is it possible to use results of another cfx simulation (in the same geometry ) to generate such a file that can be used as input like you said? thanks again. |
March 2, 2015, 11:12 |
Rep Power: 32 |
If the results you require from a previous simulation can be associated to a post-processing locator such as a boundary, surface group, etc, you can use the export functionality in CFD-Post.
Select the BC export profile, customize it for the type of export you require and the .csv file written can be then imported into CFX-Pre. You may need to read the CEL syntax details on how to hook up such .csv file. |
March 2, 2015, 18:25 |
Rep Power: 11 |
thanks opaque for your reply.
what i want is not boundary condition. to add mass source term, I need to specify temperature for this added mass as an input. I want to use temperature field from a previous simulation as temperature required in mass source term tab in cfx . Is it possible to this in cfx using the export functionality in CFD-Post that you mentioned? thanks a lot. |
March 2, 2015, 20:31 |
Rep Power: 32 |
It will export as you need. However, the file may be large and I am not sure about the performance of the software dealing with it.
I would try it in a coarse mesh first, and see if it work as you desire, and then go for the final mesh. |
cfx, input value, source term |
Set a Source/Sink Term into a approriate cell | QuocHung_Phan | FLUENT | 0 | November 24, 2012 08:05 |
lid-driven cavity in matlab using BiCGStab | Don456 | Main CFD Forum | 1 | January 19, 2012 15:00 |
mykEpsilon - How to set a min/max constraint for a term with units | elektra79 | OpenFOAM | 3 | October 12, 2010 18:12 |
Plasma Flow Modelling using Source term and cell's data | Constantine | Fluent UDF and Scheme Programming | 2 | May 19, 2010 21:06 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
