A Cylindrical Coordinate Frame problem in CFX |
March 26, 2015, 10:14 |
I would like to create a velocity profile at the inlet side of a duct, obviously due to the presence of the boundary layer. Since CFX works in terms of Cartesian coordinate system, how can I do it? I've read all the previous posts I could find regarding this topic, but, unfortunately, nothing has really helped me Thanks a lot in advance |
March 26, 2015, 10:51 |
Thomas MADELEINE
Rep Power: 11 |
you can have cylindrical component in CFX or create your own component system with CEL expressions.
I don't understand why you want to model the boundary layer in the inlet face... Do you know the size of the boundary layer here ? it can vary quite a lot from what there is before... you can always extend your domain just a little (10 cells in duct direction) and add a free slip wall to avoid the boundary layer problem, but then you will have a very small boundary layer. Or you can use the massFlow option as inlet and let CFX do the rest, but i am not sure it will be more accurate... |
March 26, 2015, 11:01 |
#3 | |
The inlet duct is extremely long. I think that I can avoid modeling the ENTIRE duct if I model a velocity profile according to the equation v/vinf = (y/d)^(1/n) being v = local velocity; vinf = velocity outside the boundary layer; y = distance from wall; d = local boundary thinckness; n =7-9 It would be extremely helpful if you could add some more details on "create your own component system with CEL expression". Thanks again for your help |
March 26, 2015, 11:03 |
#4 | |
d = 0.270 * l * Rel ^(-1/6) (if n = 9), being l the duct lenght |
March 26, 2015, 11:26 |
Thomas MADELEINE
Rep Power: 11 |
If you know your geometry well enough to have the equation of your inlet circle then you can create your own components:
supposing C the center of your circle Xc the X coordinate etc... create a new expression R = sqrt( (X-Xc)² + (Y-Yc)² for a circle in the XY plane then create the function V(R) and use it as velocity inlet... I don't know by heart the name of CEL function so don't copy paste... |
March 26, 2015, 11:27 |
.... THANKS A LOT! It was the help I neeeded!
Coordinate Frame Motion | yangxu | CFX | 6 | January 25, 2022 08:51 |
Overflow Error Because of defining a New Coordinate Frame | ashtonJ | CFX | 3 | April 23, 2012 08:08 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
question about governing equation in CFX using rotating/non rotating reference frame | rystokes | CFX | 0 | January 12, 2010 06:14 |
singularity problem in cylindrical coordinate | dallybird | Main CFD Forum | 6 | June 3, 2003 11:47 |
