Stop criteria in CFX
Old   October 13, 2015, 22:27
Default Stop criteria in CFX
MissCFD is on a distinguished road
Is it possible to set a convergence criteria to stop once it has reached an asymptotic limit ?
Thank you very much for your help
MissCFD is offline   Reply With Quote
Old   October 14, 2015, 05:36
Antanas is on a distinguished road
I guess yes. You should use interrupt condition.
Antanas is offline   Reply With Quote
Old   October 14, 2015, 08:11
Yes, but how do we take into account the previous iteration in a expression ?
For example, if I want to stop the convergence when:
Qte,max-Qte,min < 1% during twenty iterations ?
Old   October 15, 2015, 09:58
Sorry I don't understand what you want exactly, but if you want to stop when a quantity reach prescribed value asymptoticaly, IMO it means that two conditions satisfy at the same time:
1. quantity value becomes close enought to target value
2. its time derivative -> 0.
In this case there's no problem to implement such condition using if-CEL expression, for example: if((abs(quantity - target) < eps1) && abs(quantity.dt) < eps2,1,0)
Old   October 23, 2015, 16:50
Sorry, but I don't understand how work the Interrupt Control Conditions in CFX !
Where and how I have to write the logical expression ? In the tab ''Expressions'' or in ''Logical Expression'' of the tab ''Solver Control'' ?
What am I supposed to write in ''Logical Expression'' of the tab ''Solver Control'' ?
I would like that the solver stops when the imbalance of mass flow is below a certain level. So I have the expression following: if(Imbalance < 10^-4, 1,0).
Old   October 23, 2015, 18:47
Opaque will become famous soon enough
MyImbalance = abs(massFlow()@MyInlet - massFlow()@MyOutlet)
Logical Expression = if(MyImbalance < 10^-4 [kg s^-1], 1,0)
Hope the above helps,
Opaque is online now   Reply With Quote
Old   October 24, 2015, 03:27
For imbalances there's 'conservation target' convergence criterion. You may set it for all equations or on equation class basis.
Anyway, interrupt conditions are set inside Solver Control on Basic Settings tab (look for 'Interrupt Control' checkbox).
Old   August 7, 2022, 16:20
Murillo is on a distinguished road
Yes, it is possible to do it so. Check "ANSYS CFX Solver Modeling Guide". A section called "Using Interrupt Control in Cases with Transient Convergence Behavior" describes how you can do it.
Murillo is offline   Reply With Quote
CFX Pre & Post Startup Error vigges CFX 12 March 17, 2023 03:30
CFX problems I got in Workbench Anna Tian CFX 13 July 3, 2017 01:49
cfx solve error and stop solve and fail solve mahdidelfan CFX 4 July 3, 2014 02:01
Trying to stop CFX running mannually cfxmar CFX 8 August 27, 2010 11:00
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
