Error of component upstream for starting solution |
October 16, 2015, 10:57 |
Aja
Rep Power: 14 |
I am simulating an using CFX as a solver. This turbine have 8 blades((360/8)=45 deg=pitch angle). Due to the circumferential symmetry, only one eight of the annulus has been computed, imposing periodic boundary conditions (periodic rotational) in the tangential direction. The computational domain has been restricted in the axial direction to four chord lengths upstream and six chord lengths downstream of the blade.
I wanted to solution start, but the following error is appeared: I am grateful that guide me. Thanks. Best. Aja Last edited by aja1345; October 19, 2015 at 06:39. |
October 20, 2015, 03:35 |
Maxim
Rep Power: 12 |
isn't that error message pretty clear? For some reason, the solver manager cannot find the solver input file (.def) from CFX-Pre. Double-check if the .def file is in the right folder...
October 20, 2015, 04:11 |
#3 | |
Aja
Rep Power: 14 |
I am new in CFX. Please see the following attached video file: http://www.4shared.com/video/fbD7qPA...titled_89.html Is there any problem in this video about solver input file? Thanks, Best, Aja |
October 20, 2015, 04:19 |
Maxim
Rep Power: 12 |
sorry I don't download files from random people on my windows pc/working environment can you upload it so that I can stream it or take screenshots?
October 20, 2015, 04:32 |
Aja
Rep Power: 14 |
October 20, 2015, 04:36 |
Maxim
Rep Power: 12 |
looks fine. Try right click on 'solution' - Reset. (This deletes data and settings from the solver manager. Since you haven't created anything yet, that should be fine). Try again to start it. Sometimes workbench has a hiccup.
CFL Condition | Matt Umbel | Main CFD Forum | 19 | June 30, 2020 08:20 |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 21:22 |
Doubt on Implicit Methods | analyse In India | Main CFD Forum | 10 | March 9, 2007 03:01 |
Discussion about Mesh independant solution | Seb | Main CFD Forum | 13 | May 22, 2001 13:37 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
