How can I use solution from one simulation as initial condition on a remote solver? |
October 21, 2015, 17:45 |
Daniel Norton
Rep Power: 11 |
I'm currently using a remote solver for some simulations, but setting the simulations up locally. Is it possible to use the solution for one simulation as the starting point of a second simulation? Ideally, I would reference the results file created from the first simulation as the initial conditions for the second file. Being able to do so would substantially decrease the amount of time necessary to complete a grid independence check. My problem is that I have to specify the initial condition file path, which will not be the same as the local file path on the remote solver. This file ideally won't even exist until the batch process has started. I can predict what the name of the results file from the first simulation will be and it will save into the local directory. Thanks for your help. |
initial result file, remote solver |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Wrong fluctuation of pressure in transient simulation | caitao | OpenFOAM Running, Solving & CFD | 2 | March 5, 2015 21:33 |
Simulation seems to converge but crashes suddenly | xxxx | OpenFOAM | 16 | September 12, 2014 08:07 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
