How to Plot Graphs of Parameters (Not Convergence) in ANSYS CFX? |
December 22, 2015, 01:41 |
Dear all,
Hi. Hope everyone is well. I wanted to ask how can I plot graphs of four parameters: pressure drop (ΔP), friction factor (f), heat transfer coefficient and Nusselt number (Nu) versus Reynolds number for a counter flow double pipe heat exchanger? Should I use formulas or is there any option where automatically these graphs can be plotted? I have successfully made the model and now want to plot graphs. Would be grateful for help by expert people. God bless you all. Thanks. |
December 22, 2015, 04:34 |
Rep Power: 143 |
It is best if you develop the formulas for these parameters yourself. Then you know exactly what parameters went into them.
December 22, 2015, 04:53 |
Thanks for the reply Ghorrocks. I wanted to ask how should I use the formulas and what is the procedure? Is there any way to select parameters on x and y axis and then plot? I have never done this, so don't know how. For example h=q"/(T_wall-T_bulk) and Re=ρVD/μ. From where would I get the parameters used in the formulas and how to plot these graphs? Would be grateful for help. Thanks.
December 22, 2015, 05:29 |
Rep Power: 143 |
You can use CFD-Post to graph these things but I do all my plotting in other packages like tecplot and python.
For Re = rho*V*D/mu - you need to define expressions which evaluate these input variables. Then a simple expression gives you Re. Have a look in the tutorials for examples of CEL expressions. |
December 22, 2015, 08:50 |
Thanks Ghorrocks. Where would I get ρ, V, D, and μ from? and after I make expressions how to plot them. Would be grateful for your help. God bless you. Thanks.
December 22, 2015, 17:01 |
Rep Power: 143 |
You get those values from whatever is an appropriate definition of them to get Re in your case. If the flow is incompressible then density is obvious, if compressible you could use either a domain average or the free stream density. Velocity is probably the free stream velocity, or the average velocity over the pipe cross section. D is an appropriate length scale - either a length, width or diameter.
December 24, 2015, 08:46 |
Thanks Glenn. I have made the expressions. Now how should I plot heat transfer coefficient versus Re? Do I need to plot in CFX-Solver or CFX-Post? Would be grateful for help. God bless you. Thanks.
December 25, 2015, 03:58 |
sunil
you can plot it in CFD-post not in CFX-pre
December 25, 2015, 09:02 |
Thanks all. How can I plot graphs of variables in CFX-Post?
Compressible Flow in Ansys CFX | bcheruk | CFX | 15 | July 6, 2017 06:30 |
error about fsi in CFX and ANSYS | WANGFIRE | CFX | 1 | April 21, 2015 01:48 |
CFX overwhelming Fluent in mass convergence of boundary layer separation case | Pierre1 | FLUENT | 7 | March 26, 2015 21:43 |
Time step dependence of convergence behavior of steady state simulations in CFX | Chander | Main CFD Forum | 5 | December 23, 2013 05:31 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
